I have a mgb gt v8 conversion currently off the road for some restoration work and have often wondered about fitting a 48 idf , its fitted with a pair of SU's. Machining the turret off fabricating an adaptor and tigging it on is no problem. I've seen this sort of thing done to fit the 38dgas and the 40 dfa. I wondered if anyone here has done this and what would be the correct jetting for this would
be on s stock 3.5.
Cheers R
48 IDF
Mc Tool
- Helpful or Confused
Re: 48 IDF
How are you going to fit that under the hood, I know you can fit dcoe and keep it all inside
Charred fingers
Re: 48 IDF
Machining the turret will take off about 80 mm. The carb excluding ram pipes is 136mm tall. There is clearance above the turret as it stands something i can check with a collapsible cardboard tube.. I don't mind fitting a power bulge as the SU's already have them
Mc Tool
Re: 48 IDF
Yeah , I like power bulges . Location is a shame , I could have offered you a edelbrock performer manifold and holley 390 vac sec , I have had them on an engine for years and it has never been run so as brand new
Re: 48 IDF
McTool
That engine looks very neat, what sort of specifications etc?
Presume 3.5 and it looks like a P6 front end!
Mc Tool
Re: 48 IDF
Its an early rope seal block, 3.5 , converted to lip seal , shot peined and polished rods, 10.5:1 comp (fly cut pistons )hyd fast road cam , vernier double row camchain/sprockets , efi valves ,bronze guides , head and main stud kits , rod bolts ( arp )tall rotor kit and mg spring in oil pump and the whole lot ( inc clutch and flywheel )ballanced. The fast road cam is a bit over the top with .510" lift, hence the bronze guides ,it just squeeks past the coil bind test but the lift is a bit pointless needs to be reduced a bit and I never did make up my mind how to do this , either a new cam or get this (billet) cam reground. Its been around since 1997 . I have since got an serp 3.9 and plan to sell this 3.5 motor but I dont want to pass on any issues re the cam so I gotta do something . I have an efi set up so I figured if I have the carb & manifold off might sell that and put the efi on to sell motor . There is a w57 toyota 5 speed and dellow bell housing too.
