Gobsmacked.
- ihatesissycars
Gobsmacked.
http://www.youtube.com/watch?v=QsmiIeAkE-o&NR
- ihatesissycars
I assume its is computer written programe, that would be mind numbingly hard to programe manually, and just one zero too many, and WHOOPSIE, or set the datum to a minus point. I did see an appreitice run an unchecked programe with a -z axis datum set to about 70mm below the table height, that made a mess of a very expensive machine
I did hear a rumour that the tutor for our lathe and mill class (back in the mists of time when I worked for Britannia but did my first year at Bae) managed to wipe out a 146 wing.... probably not the best thing to do, one big chunk of metalian.stewart wrote:I did see an appreitice run an unchecked programe with a -z axis datum set to about 70mm below the table height, that made a mess of a very expensive machine
- HairbearTE
- Guru
