Gobsmacked.
ihatesissycars
Gobsmacked.
Post by ihatesissycars »
http://www.youtube.com/watch?v=QsmiIeAkE-o&NR
:shock: :o
Post by ian.stewart »
I could do that on my 3 axis bridgeport, only take an afternoon :lol: :lol: :lol: :lol:
THE SMOKING GNU
ihatesissycars
name yer price!
IainB
Post by IainB »
Holy crap....I knew I should have taken more notice in my CNC lessons :(
I assume its is computer written programe, that would be mind numbingly hard to programe manually, and just one zero too many, and WHOOPSIE, or set the datum to a minus point. I did see an appreitice run an unchecked programe with a -z axis datum set to about 70mm below the table height, that made a mess of a very expensive machine
THE SMOKING GNU
IainB
Post by IainB »
ian.stewart wrote:I did see an appreitice run an unchecked programe with a -z axis datum set to about 70mm below the table height, that made a mess of a very expensive machine
I did hear a rumour that the tutor for our lathe and mill class (back in the mists of time when I worked for Britannia but did my first year at Bae) managed to wipe out a 146 wing.... probably not the best thing to do, one big chunk of metal :oops:
Question is - did it run?
Lewis
Post by Lewis »
The Melling Hellcat V10 has heads & block milled from solid billets of alloy. Perfectly do-able! :shock:
http://www.youtube.com/watch?v=Mute_Vm4pXs
Sounds quite good too, not convinced entirely by the looks though! Quite tough lookin' I guess :twisted:
Mark
Post by Mark »
That is a COOL vid 8-)
They are just showing off by finishing the bores with a ball nose and pivoting the block every which way when a boring bar would be much quicker. No way on earth would you want to program that manually :shock:
Mark
HairbearTE
Post by HairbearTE »
I have to agree, that vid is amazing. Great spot Gav. :nw
scoobyv8
Post by scoobyv8 »
thats just beautiful! cad cam at its best.
The refinement of modern day comfort, and the prestige of a rover V8! In the making.
alex
Post by alex »
Good vid.
The jetsprint boys in aus and nz are starting to run billet blocks, they get a 502 cu in out of a small block size from what i understand. they are awesome to watch.
Return to “General Chat Area”
