Hi all,
Can someone tell me what oil I should be using for the Capri LSD diff? All I'm getting from most sites is 'refer to main dealer' not very helpful!
Many Thanks
Kev!
Diff oil question
Diff oil question
RX-7 Bitza
This is probably little more helpfull than the other answer you are already getting, but I would use Hypoid 90 diferential oil (non synthetic) , avoid anything fancy as those clutches will have been designed to work with what was available when the axel was made, I would avoid 80 weight unless it is very cold as the clutches will be dumping heat into the oil over every bump and turn.
Castrol used to sell EXP90, which has extra addative to prevent oil breakdown in shear conditions, Ive been using the stuff in my LSD for years,
IIRC Ford used to sell a bag of powder to add to normal EP90 for capri LSDs
- russell_ram
You want this
http://www.merlinmotorsport.co.uk/p6695 ... _info.html
or maybe this
http://www.lucasoil.com/images/medialib ... ar_oil.pdf
or this
http://www.millersoils-online.co.uk/M3_ ... t&cart_id=
I use the Havoline in my Jag LSD,
Russ
or maybe this
or this
Russ
