Diff oil question
Wizardof
Diff oil question
Post by Wizardof »
Hi all,
Can someone tell me what oil I should be using for the Capri LSD diff? All I'm getting from most sites is 'refer to main dealer' not very helpful!
Many Thanks
Kev!
RX-7 Bitza
This is probably little more helpfull than the other answer you are already getting, but I would use Hypoid 90 diferential oil (non synthetic) , avoid anything fancy as those clutches will have been designed to work with what was available when the axel was made, I would avoid 80 weight unless it is very cold as the clutches will be dumping heat into the oil over every bump and turn.
gelmonkey
Sergeant Monkey Face
Post by gelmonkey »
Hi Kev
I am running an LSD in my Cavalier and was told that I should use the correct oil otherwise it could cause problems.
Bardahl produce an LSD oil but you could always try a gearbox/transmission specialist for the right stuff.
Paul
r2d2hp
Post by r2d2hp »
I use Castrol B373
Post by ian.stewart »
Castrol used to sell EXP90, which has extra addative to prevent oil breakdown in shear conditions, Ive been using the stuff in my LSD for years,
IIRC Ford used to sell a bag of powder to add to normal EP90 for capri LSDs
THE SMOKING GNU
Wizardof
Post by Wizardof »
Thanks for all the info gents!
I'll take that away and see what i can find.
I actually contacted Ford as well and they said they don't even see the oil for this diff any more! fat lot of good they are!! :-)
cheers
Kevin
RX-7 Bitza
russell_ram
Post by russell_ram »
