hiya all,
Where would be the best place to get my 4.6 block re-bored.
Anyone got some good places to recommend.
I'm up in the north-east of england...so local ish would be nice.
I'm not after flanged liners, just a standard rebore.
scott richmond
4.6 block rebore?
- Seight-V8
There is not a option to re-bore the 4.0 as you can't get +10 pistons or rings
but on the 4.6 you can get +10 and +20 piston and rings.
Try V8 Developments.
V8 Tuner has +20 4.6 pistons. If the Block has a blob of red paint in the valley you should be ok but it would probably be wise to have the block pressure tested before doing any boring. Check that all the liners are level with the tops of the block, it should be obvious if any of them have moved.
- Seight-V8
hiya all,
so far i think my 4.6 block looks ok.
The cast date shows 1997.
And its got 3.0 written on the inside of the valley.
Reading the books this means it's got 3.0mm between the casting and the liner.
And the liners are sat on a small shoulder right at the base of the cylinders, so they shouldnt drop.
So hoping pressure test will be ok.
scott
scott
- HairbearTE
- Guru
