Killed my LSD!
dnb
Killed my LSD!
Post by dnb »
Took the Griff out for a bit of a hoon tonight and realised that the right hand rear wheel was just spinning on hard acceleration.
So the LSD is finally dead.
It's been knocking for ages, but tonight has killed it.
So, where can I get parts for an antique GKN diff?
What parts ?
Can you just replace the diff unit itself with another, or is the CWP damaged too ?
Gearboxman ? That Gripper diffs guy ? Quaife ?
John Felsted might know some LSD contacts too ?
davemgb
Post by davemgb »
Why not try GKN - http://www.gkndriveline.com
dnb
Post by dnb »
CWP should be fine - under light use, the car behaves.
GKN driveline seem to be a bit like Delphi - not interested unless you order several million of anything :(
I'll speak to some contacts on Monday.
davemgb
Post by davemgb »
I thought GKN had a small department somewhere that dealt in one off repairs for enthusiasts - only reason I suggested them.
dnb
Post by dnb »
They may do, but I haven't found it yet.
I'll keep looking :D
Phantom Grip form Jon savage at Cmabridge motorsports is a good budget locker.
I've emailed GKN on 3 occasions asking for someone to contact me about advice and prices for a LSD but they never return the messages?
Robrover
Post by Robrover »
A Quaife ATB would be a good option and probably more enduring.
russell_ram
Post by russell_ram »
dnb,
I'm not familiar with the TVR diff as such, but if it's a GKN 4H based unit, as are many, then it is the same core internally as any of the Jag units. I rebuild lots of those for the Cobra community and might be able to help you out (or any of the std Jag people - Wards, John gordon, SNG Barret etc).
Russ
dnb
Post by dnb »
Thanks Russ!! YHPM
I don't believe TVR would use anything totally unique. Bespoke mechanicals were simply too expensive for them at the time. I'm fairly sure it will be as you say - standard Jaguar.
CarlosV8
Post by CarlosV8 »
Apologies for digging this up from the depths of the forum, but it appeared in a Google search.
I'm looking at getting the GKN diff in my TVR rebuilt - if dnb is about, what did you do with yours in the end?
Carl
Carl
1986 Rover SD1 Vitesse TP
1996 TVR Chimaera 400
dnb
Post by dnb »
Sorry for spotting this so late! The TVR diff is borrowed from an old Maserati, and if you have the LSD GKN diff it is already a Quafe ATB type thing. Nice when it works.
I managed to find some spares for mine. It turns out the LSD itself wasn't dead, but the bearings were destroyed causing lots of shunting and general ill behaviour.
(Diagnosis wasn't helped by me completely destroying the clutch at the same time, but that's another long story involving a shredded friction plate due to the clutch not being fit for purpose and a very big argument)
I had a local mechanic - a historic rally car specialist - rebuild the diff with new bearings and solid shims instead of the collapsable thing it had from the factory. Some bearings were hard to get so we had to improvise a little.
It's a couple of years on now and the diff has never been better. I can recomend the solid spacer route as far superior to standard if the car has any power/torque increasing mods.
