water temp sender
water temp sender
Hi,I need to connect my ford capri water temperature gauge to a chevy v8 sender unit,will this give accurate readings or do I need to buy an aftermarket temp gauge,cheers Dave
why not do what we do with the RV8,
drill out the Chevy center and tap it out to fit the ford sender, chevy to ford conversion then sorted
yup drill out the sender center, if its big enought to take the ford sender,dave350v8 wrote:Do you mean drill out the centre of the sender unit,or drill out a suitable blanking plug then tap that out?
