water temp sender
dave350v8
water temp sender
Post by dave350v8 »
Hi,I need to connect my ford capri water temperature gauge to a chevy v8 sender unit,will this give accurate readings or do I need to buy an aftermarket temp gauge,cheers Dave
Post by ian.stewart »
the easy way to do this would be fit the Capri sender into the Chevy, Then you will know the sender is working correctly rather than hoping it is!!
THE SMOKING GNU
dave350v8
Post by dave350v8 »
Good Idea! Thanks for quick reply,may need an adapter though.
why not do what we do with the RV8,
drill out the Chevy center and tap it out to fit the ford sender, chevy to ford conversion then sorted
dave350v8
Post by dave350v8 »
Do you mean drill out the centre of the sender unit,or drill out a suitable blanking plug then tap that out?
dave350v8 wrote:Do you mean drill out the centre of the sender unit,or drill out a suitable blanking plug then tap that out?
yup drill out the sender center, if its big enought to take the ford sender,
