RV8 core plugs and sealant
Fed_up_Stag-owner
Post by Fed_up_Stag-owner »
Hi All,
Never ending saga!
RV8 3.5, one core plug leaking, now removed and replaced with another, still leaking. Do I use a socket that's smaller than the plug and drift the centre of the plug into place, or do I use a socket that's the same diameter as the plug?
Which is the best plug sealant out of:
Hylotyte Red
Hylomar blue
Dirko HT red ?
All three can gap seal, are high temp and are resistant to anti-freeze
I've tried all sorts of ways. I usually try to rotate the plug by bashing one side, then pulling it. Some of them I've just bashed into the insides first before rotating. Not sure there's a right or wrong way.....
No experience of those 3 sealants you are suggesting.
I've used a slightly smaller socket with success before, with Indian Head as sealant.
Actually more of a lubricant, to be honest, a Welsch Plug should seal without any additional product if there is no underlying damage to the block.
Fed_up_Stag-owner
Thanks for the replies. Not possible to get a straight strike on the cap due to poor access, which can't help with alignment. I'll probably try the Dirko sealant.
Return to “Cooling Area”
