Hi All,
Never ending saga!
RV8 3.5, one core plug leaking, now removed and replaced with another, still leaking. Do I use a socket that's smaller than the plug and drift the centre of the plug into place, or do I use a socket that's the same diameter as the plug?
Which is the best plug sealant out of:
Hylotyte Red
Hylomar blue
Dirko HT red ?
All three can gap seal, are high temp and are resistant to anti-freeze
RV8 core plugs and sealant
Fed_up_Stag-owner
- Helpful or Confused
I've tried all sorts of ways. I usually try to rotate the plug by bashing one side, then pulling it. Some of them I've just bashed into the insides first before rotating. Not sure there's a right or wrong way.....
No experience of those 3 sealants you are suggesting.
Fed_up_Stag-owner
