Help rover v8
V8XR2
Help rover v8
Post by V8XR2 »
Help rover v8 keeps killing coils
I've fitted points free electronic ignition
It ran great missed a few times now it will not spark
Coil is powered by 25amp fuse and switch detect from battery
With no Ballist resistor
Help
Have you got the correct coil?
V8XR2
Post by V8XR2 »
I've got the high power illumination coil that came with the ignition kit
Could a fallty rev counter kill coils ???
V8XR2 wrote:I've got the high power illumination coil that came with the ignition kit
Is 'illumination' a variation of 'lumenition', which is renowned for being crap?
Darkspeed
Post by Darkspeed »
What do you mean by points free - Lumenition covers a few types - The Optical trigger type - which I have personally never had any issues with and the more recent "Magnetronic" electronic points type?
4.5L V8 Ginetta G27
When my car had a dizzy, it went through a bunch of coils/ignition amps because the regulator on the alternator was shot and it was cranking out too many volts.
Denis247
Post by Denis247 »
Mounting the coil away from heat sources helps, I've seen coils mounted direct on the block, and UPSIDE DOWN so all the oil leaks out!
Assuming it's not just heat killing the coils, it could be too much current caused by too high voltage ie incorrect coil designed for ballast working but without the resistor, or wrong dwell angle ( some electronic ignitions are just transistor assisted points), .
When one of your coils fail, does it go open circuit on the lt side? Or how else has it failed?, ht side?,
