Help rover v8 keeps killing coils
I've fitted points free electronic ignition
It ran great missed a few times now it will not spark
Coil is powered by 25amp fuse and switch detect from battery
With no Ballist resistor
Help
Help rover v8
Mounting the coil away from heat sources helps, I've seen coils mounted direct on the block, and UPSIDE DOWN so all the oil leaks out!
Assuming it's not just heat killing the coils, it could be too much current caused by too high voltage ie incorrect coil designed for ballast working but without the resistor, or wrong dwell angle ( some electronic ignitions are just transistor assisted points), .
When one of your coils fail, does it go open circuit on the lt side? Or how else has it failed?, ht side?,
Lotus Elite 4.6 Spydersport 'Donington' conversion
