Lt77 short gear linkage
I need to move the gear lever forward on my lt77, currently have a stock lt77 from a vitesse. Not exactly sure how much it will need moving but likely to be 3 inches of so
Could the existing one be shortened?
Otherwise what car/van will I need to get one from?
You can shorten a standard lever housing as that's what I had on my MGB. Need someone who can weld cast alu tho .....
Not sure on other linkages. I have a sherpa one in the garage somewhere but have no idea where!
This one is pretty short!
http://www.google.co.uk/imgres?sa=X&biw ... 524T2eC16d,!)0E9s37HlMQBRMjG,TNj!~~60_35.JPG&w=300&h=225&ei=aq5FUrjpMIWc0QXx_YDICA&zoom=1&iact=hc&page=1&tbnh=137&tbnw=179&start=0&ndsp=21&ved=1t:429,r:5,s:0,i:98&tx=127&ty=50&vpx=868&vpy=2&dur=640&hovh=180&hovw=240
I defo have one of those in the garage as I have the gearbox for an abandoned RWD turbo diesel project lol.scudderfish wrote:I seem to recollect that the lever housing from a V8 Sherpa van was the shortest you could get, possibly the one in the image above.
