Vortech Chargers
ah thanks mate, didnt realise it was a bigger charger,
i am looking for a smaller body one to be honest,
i gather the V1 is smaller than the novi mentioned?
if so is that the smaller one in the vortech range dimension size wise?
thanks for your help again Stevie T.
Coops wrote:ah thanks mate, didnt realise it was a bigger charger,
All the dimensions can be found on the relevant websites.
well 15mins on and still searching vortechs site :lol:
found every thing but the dims
but have found this site that could be handy.
http://www.capa.com.au/vortech_v7.htm
If any one else finds any similar info with diagrams let me know please as going to set a section up on the forum with charger dimensiions to make it easier for peeps to work the sizes out.
Coops wrote:well 15mins on and still searching vortechs site :lol:
I was sure I seen them there before...or on some site !!
ged
Post by ged »
This any good to you?
http://www.capa.com.au/vortech.htm
Click on the charger & scroll down, it gives dimensions.
Edited to say "I need to read previous post's properly":roll:
Regards Ged
The smallest dia centrifugals are rotrex. Not far behind is the procharger c1&2 but these are less deep than the rotrex.
Tom
Right,
before i rush out and start buying chargers,
what max boost should i be putting into the 4.6 reallisticly (and no replies like as much as you can now Stevie, be good :lol: )
as need to work out what rpm the charger needs to turn etc to get the right matched pulleys,
the serp bottom pulley on the rv8 is around 6.75".
Coops wrote:Right,
Not as simple as that. You'll have some time trying to figure out pulley sizes for a specific boost level. You'd need to know the exact air consumption of your engine at any given time along with god knows how many other things
If your blower is listed as being capable of supplying air for 500bhp, then spin it to the maximum. Chances are you wont actually make 500bhp though due to various losses.
But IMO that would be the easiest way to establish a pulley size to aim for. Chances of getting it right first time are slim.
Just build the engine with a little safety into the CR with regards to boost. But even 9.0:1 should be quite safe.
not sure on the CR at present mate, think its higher than 9.0 :lol:
hence why we talked about a while back of only going to about 8psi of boost.
It will be difficult to select pulleys to give you a certain boost level.
I'm around 9.5:1 and around 20psi at 7k
The fact these blowers dont make a lot of boost in the mid-range, means you can get away with a higher CR.
Plus the fact boost is always rising with rpm.
spose fit the biggest charger pulley i can off the shelf and see what happens :shock:
i think the biggest pulley vortech do is 5" for the charger.
r2d2hp
Post by r2d2hp »
Dont you mean smallest pulley Tony, smaller means it spins faster
Hi Tony
Can I point out that it was neither Stevie nor me that posted that :lol: :lol:
i know mike :lol:
yes Reg BUT i dont want to put 26 psi into my little rover v8,
hence the BIGGER pulley to slow it down :lol: :lol:
Return to “Forced Induction”
