smoke on over run :-(
i think its around 22.4lb i maybe wrong.
- topcatcustom
cos that who im sending the £1550 bill tootopcatproduction wrote:Why did they stamp my initials above the front cam bearing though?
Cheers for popping them gaskets down tonight Rossco, was good to meet you at long last mate
hello mate where you been hiding????dnb wrote:Looking good
Hope to see you in a week or two for some running in & mapping.
hope so Dave, hope to have her running this weekend,
Well had a bit of spare time after work tonight so started on the engine,
Start of crank install,
shells coated with Graphogen paste, man this gets everywhere
crank sat on shells and caps starting to be installed.
all caps fitted and crossbolts fitted, and it turns over free by hand, PHEW
start of the piston install, this is where im at tonight, crank in and torqued, and two pistons fitted,
they do arf take a lot off when they balance parts dont they
- topcatcustom
well its good to have ya back mate
Right:
Got a bit more done tonight:
all pistons are now fitted, (the crowns sit near flush with the block face when at the top of the bore)
my adjustable cam gear i use behind the interim cover,
SD1 baffle plate fitted to the block along with the oil pick up,
Right:
