smoke on over run :-(
i think its around 22.4lb i maybe wrong.
ppyvabw
Post by ppyvabw »
sidecar wrote:
A case of mixing up kg and lbs going on here! :wink:
:lol: Ooops. Now don't I feel stupid :oops: :oops:
seight
Post by seight »
Looks good mate.
Is that number -008 ? Could it mean 8 thou' removed from the decks? That's probably enough to nearly remove the engine number.
Mike :D
JSF55
Post by JSF55 »
I'd go along with that, seems a reasnoable amount to ensure the deck was square to the bores, over stamp them with V8 Kid 1 :lol:
So thats where it went !
Rossco
Moderator Gold
Moderator Gold
Post by Rossco »
I'd hope that they would have equalised the deck height as well.
topcatcustom
Post by topcatcustom »
Why did they stamp my initials above the front cam bearing though? :lol:
TC
topcatproduction wrote:Why did they stamp my initials above the front cam bearing though? :lol:
cos that who im sending the £1550 bill too :lol: :lol: :lol:
Cheers for popping them gaskets down tonight Rossco, was good to meet you at long last mate :lol:
dnb
Post by dnb »
Looking good :)
Hope to see you in a week or two for some running in & mapping.
dnb wrote:Looking good :)
hello mate where you been hiding????
hope so Dave, hope to have her running this weekend,
Well had a bit of spare time after work tonight so started on the engine,
Start of crank install,
shells coated with Graphogen paste, man this gets everywhere :lol:
crank sat on shells and caps starting to be installed.
all caps fitted and crossbolts fitted, and it turns over free by hand, PHEW :lol:
start of the piston install, this is where im at tonight, crank in and torqued, and two pistons fitted,
they do arf take a lot off when they balance parts dont they :shock:
topcatcustom
Just a bit! Looks nice though tony you must be well chuffed!!!
TC
seight
Post by seight »
Is that piston pointing the right way? :D :P
Mike :wink:
dnb
Post by dnb »
thev8kid wrote:hello mate where you been hiding????
Mostly at work. Have had too many tight deadlines recently...
well its good to have ya back mate :D
Right:
Got a bit more done tonight:
all pistons are now fitted, (the crowns sit near flush with the block face when at the top of the bore)
my adjustable cam gear i use behind the interim cover,
SD1 baffle plate fitted to the block along with the oil pick up,
