rover sd1
bones
Post by bones »
sorry for not replying earlier, still trying to get the funds for the quaife, its for street and strip use, :) rich
bones
Post by bones »
Ok ive got a lsd multi-plate, but need some info on it. It looks like a Trans-x type, but the name on it is LEMAX, its got 4 plates one side, does that mean it will slip abit more before tightening?? and where can i get plates from, all advice welcome :) rich
Wotland
Post by Wotland »
bones wrote:Ok ive got a lsd multi-plate, but need some info on it. It looks like a Trans-x type, but the name on it is LEMAX, its got 4 plates one side, does that mean it will slip abit more before tightening?? and where can i get plates from, all advice welcome :) rich
Hi Rich, where did you find this Lemax LSD ?
bones
Post by bones »
i got it from another forum member :) rich
Post by CastleMGBV8 »
Rich,
Sounds similar to the Jagpowerlock diff that has clutches or clutch type plates.
Did an extensive search for the names you provided and came up with silch
apart from a few links to sites of people of uncertain gender :lol:
Is this diff specifically for the SD1 axle?
bones
Post by bones »
i wouldnt of thought so, it came out of a v8 :) tr7. i found nothing on it either :?
Rich,
Same diff casing then.
Kevin
bones
Post by bones »
same size diff housing, but more in closed than the sd1 type. On one side its got 4 plates, 2 look like spacers and the other 2 have 4 i suppose lugs on them that fit in a casing> im no good with the names of things or describing them as it goes,or have you already guessed that :( rich
sowen
Post by sowen »
Something like this?
I have no pictures of the breakdown of the plate clutches. I think from memory there are 3 plates each side with 4 tabs that locate in the case, and two splined plates that locate on the two larger spider gears that the output shafts locate.
1972 Rover 2000TC M16 turbo
1975 Land Rover OM606 diesel
Alan!
We only do RWYB Drag Racing at a DIY level. So scrutineers aren't bothered.
And for me with MGB diffs being given away, I have a good supply of cogs and shafts :)
bones
Post by bones »
the end looks different to mine, well ive decided to take it to websters to get soughted, as i have,nt a clue how to pre-load the damn thing. Does anyone know where i can get the plate kits from????? :? rich
bones
Post by bones »
bones
Post by bones »
bones
Post by bones »
Is it from a P6 ?
