rover sd1
bones
rover sd1
Post by bones »
Hi all, does anyone know where i can get the planet wheels( stupid name for them?) for the rear axle on my sd1, they both broke into little pieces today,(bless em ),or is there a stronger item i can use? :cry: rich
Robrover
Post by Robrover »
Quaiffe lsd - costs but will handle considerably more power/torque than the standard differential.
Sherpa van, J4 van, Austin Westminister, maybe big Healey? may all have the same internals and links to the SD1 axles/diffs and are stronger.
topcatcustom
Post by topcatcustom »
Weld it up Rich! Then you can stop that 1 wheel you keep spinning on the line too :wink:
bones
Post by bones »
Hi all, looks like quaife is the way to go, it will do away with the weak suff, can it be fitted by me :? or should i let someone who knows what they are doing fit it,?? ,and thanks for the replies :) rich
Post by CastleMGBV8 »
Rich,
Did you just change the crown wheel and pinion for the 3.44/1 ratio or was it the whole lot including the diff (plenetary) gears.
I think that the lower ratio is from a 2600, just wondering if the planetary gears are weaker.
Thats the 5th time today that a post I made didnt come up. I just keep getting an error message??
bones
Post by bones »
ive been getting a de-bug mode message come up,but message still goes on forum. The only thing changed was the crown wheel and pinion, all the rest was v8 gear,had a chat with real steel when they raced the sd1, they changed to a quaife and used stronger shafts and ran 11s in it with no problems :) rich
That's a funny one Rich!
If you go to many MG forums for V8 conversions they will tell you to swap the Salisbury axle for an SD1 unit as they are stronger.??
But mine is running a stock V8 MGB axle with secondhand MGB 1800 half shafts as they are all the same.
My main failure was the small diff cogs. But this problem was solved when I welded the diff solid. But I would not like to drive mine on the road like this.
Maybe it's time to take the SD1 off the road and weld the mutha up??
It's a lot cheaper than buying a LSD unit mate :)
topcatcustom
Pel, your fear of driving on the road with a welded up diff could be made worse by your huge sticky tyres? If that is the case then Rich wouldn't have as much of a problem I'd have thought..? Rich why not weld one up as a test, cant cost much and then you could see whether you wanted to permanently use it or not!
bones
Post by bones »
welding it up could be fun and cheaper , ive looked on some other sites ,and some people have said its ok on the road but abit bumpy on bends, but really bad in the wet with slide outs when your not expecting it, The spider gears get welded and thats what ive broke, its got 225 size tyres so not wide, :( rich
Rich,
Been following this because I have a narrowed SD1 axle in my MGB which was done because I had access to one for nothing, and needed the 3.08 ratio as with the LT77 box, first gear was unusable with the original 3.9/1 MGB axle and to buy a 3.07/1 CW/P for the B axle and fit it would have cost about £650.
Have you managed to find out how much torque the SD1 axle and shafts can handle? as I have heard of people twisting the shafts once they have been been narrowed which is not applicable in your case.
I'd still like to swap in a Jag IRS but that would cost around £1800.00 after reconditioning and narrowing, but they are cheap as chips to buy and can be had with an assortment of ratios and powerlock diffs and will take up to 600BHP
Kevin
bones
Post by bones »
well ive spoke to quaife today and they said there diff will be fine for what i intend to do,the sd1 axle is ok just the diff parts are to weak for mine,but in a lighter car they should be ok.not sure about narrowed shafts being weaker and twisting, i suppose it depends on how they,ve been done,some places can respline them as opposed to welding, but im saving up and selling bits for the quaife £560 ouch :( rich
Robrover
Post by Robrover »
See http://www.gearboxman.co.uk/psdiffsquaife.html
Rover SD1 QDF16KR £495.00
bones
Post by bones »
i will get it from gearboxman, but that price is add the vat so about £560, :( rich just an update, 3 out of 4 planet gears broken, pinion has a couple of teeth slightly damaged, but it should be ok
bigaldart
Post by bigaldart »
Welded diffs are expressly forbidden in most motorsport rule books. If its racing only use a spool. Jag IRS is a pain for racing as well. Better off with a live axle.
Alan
