Rover V8 Crankshaft and Conrod Identification
Hi Guys,
not sure if some one can give me the casting numbers (HRCxxxx-ERCxxxx etc) from rover for there cranks and conrods before 11 in the morning (saturday 06/01/07),
Off to look at this rovertec engine, and things are not working out from what was paid to be built to what Neil has sat in his workshop,
so we are going to strip the engine down and have a measure up.
and wanted some numbers etc to check against parts as we remove them as a reference.
Pocket rocket
Post by Pocket rocket »
The only casting number I can find is my reground 3.5 crank (currently fitted in an SD1 block but unsure of origin).
Number is HRC 1118 OR 111B
Good Luck
Post by ian.stewart »
I use HRCs with ARP bolts, HRC is an Injection rod,
THE SMOKING GNU
i use hrc rods and crank in mine Ian,
But wanted to know if they have certain numbers for say a 3.9 crank a 4.6 a 4.0 etc so i stand a chance trying to find out what that rovertec engine has got in it.
jrv8
Post by jrv8 »
The standard 3.5 & 3.9 cranks are the same, the 4.0 and 4.6 cranks will be marked on the first web with the capacity.
The bigger capacity rods will be easily spotted as they have a rectangular block on the top cap and are held together by bolts rather than nuts.
HRC 2383 is for a 4.0
HRC 1037 is the 3.5/3.9 rod
602393 is the earlier version of the 3.5
HRC 1118 is the 3.5/3.9 crank
regards
Jim
cheers Jim have printed that off,
Boosted LS1
Post by Boosted LS1 »
You'll already know that you can make almost any capacity using earlier combinations of parts.
Boosted
