4.0L heads for 3.5L block?
Kassi
Post by Kassi »
I found that this would be incompatible.
But in my opinion I can use the new heads for the 3.5L block when using the composite gasket, optaining similar compression ratio than with the old design. As it was said many times about the third row of screws there is no need for.
Please has anybody done this conversion or has any idea why this should not be possible?
Thank you
Regards
Christof
Stuball
Post by Stuball »
I have the 4.0/4.6L heads fitted to my 3.5 engine using composite head gaskets, no problems at all.
Also you are correct, no need to worry about the 3rd row of bolts (my heads dont even have the holes for them)
Stuball
Same here Christof
I have 4.6 heads on my 3500 with comp gaskets. No problems at all.
Kassi
Post by Kassi »
Thank you guys, that was helpful for my further planning.
Kind regards
Christof
