I just bought a 7PK1970 belt. I used eBay. I have no idea what it's for, nor do I care!
A little update,
Belt now sorted, bought an 8pk2187 belt off the shelf in the UK and cut a rib off :lol: :lol:
Flywheel has now been machined and had the RST adaptor fitted, balanced and returned back to me,
[attachment=0]c4.jpg[/attachment
Rossco
Moderator Gold
Moderator Gold
Post by Rossco »
8-)
Rossco wrote:8-)
:lol:
Well after 2yrs its time for the engine to divorce the engine stand
First plate and adaptor fitted to flywheel
Second plate fitted and lined up,
And all finished,
Rossco
Moderator Gold
Moderator Gold
Post by Rossco »
It's getting exciting :twisted:
sure is mate :lol:
Of all the things....I'm kinda liking that little floor trolley the most ! lol
Like a go-jack for an engine
stevieturbo wrote:Of all the things....I'm kinda liking that little floor trolley the most ! lol
makes moving the engine about so easy lol,
can move it from the shed to the car in the garage down the garden no worries at all lol.
Right guys need some help as I'm getting myself so confused now,
am I correct in thinking I need the flat faced self centering bearing to go with this RST cover plate and not the domed type bearing face one I have sat here from my old clutch???
Post a picture of both ?
And how does each look when applied to the fingers ?
There's a good chance either cold work....but if the fingers had been flat, then a flat bearing would not work ( for long )
My current one:
you recon that will work ok then stevie?
Again, place it on top of the fingers and see how it looks.
The bearing will only travel say 10mm so there isnt a huge range of movement. If the fingers are fairly close to the centre of the bearing then I wouldnt have any concerns.
The bearing they ( not McLeod ) sent me for my clutch has me more worried...but it's working lol
If the flat part of your raised fingers where either too close to the inside or outside of the bearing, then I probably wouldnt be happy with it
gelmonkey
Sergeant Monkey Face
Post by gelmonkey »
Hi Tony
I have a twin plate Macleod clutch and used the rover release bearing
Have been running for past eight years without any issues so farDont know if this helps you?
Mr knackered
