My Range Rover Classic seems to have developed a cooling issue, and I'm running out of ideas!
On start up my RRc heater would start pushing warm air through the heater within @ 1/2 a mile, starting on LPG and warm up normally.
Recently, i.e. now the heater will start to warm, then go chilly cold, LPG vapouriser freezes and have to change to petrol until wamed through again.
Once the engine is up to normal temperature (thermostat open) all functions fine.
There are no leaks, I replaced the 82 deg thermostat (tested it after and was OK) with a 89 degree one.
This happened a few times, so went through the warm up period running on petrol, same thing happened, so this eliminates the LPG side. I also left the heater on cold to minimise the heat being drawn from the system, until warm, this obviously improves things
Wondered if the cooling system had too much pressure as rubber pipes feel as if they have too much pressure, but as stated does not pushed coolant out, I have carefully filled the system, was wondering if it was an air lock or pump cavitation??
Tonight I replaced the 15psi expansion cap, and on the drive home the rubber pipes felt the same, will find out if things are OK in the morning, not too hopefull
Engine runs fine, temperature rises to normal level, does not over heat.
Engine is a late Classic serpentine 3.9, block has top hat liners fitted, I don't believe it is be a head gasket/s, engine was up using all genuine parts, there is no water in the oil or visa versa. I haven't has a sniffer test done though
Any ideas/suggestions, I'm running out of them
