No oil pressure
paul c
No oil pressure
I started my spare 110 the other day after it had been sitting for a couple of weeks, but the oil light wouldnt go out and the gauge read nothing with a few rattly lifters, so I guess the 3.5 has lost its prime from the oil pump. Is there anything else to try without opening up the pump and packing it with vaseline?
You can make or buy a priming tool, you then take the distributor off having taken note of how it is fitted, then use the priming tool with a drill to spin the oil pump. Doing things this way you can be sure that you have oil pressure before cranking the engine over which risks damaging it.
Maybe the oil pressure relief valve has stuck open....not a big job to check.
Add an extra 3 litres of oil
Tha way the pump should be lower than the sump level and be full
Crank it over to ensure you are getting presure then drain the sump back to the correct level
Messy but easier than dizzy off in my world!
- SimpleSimon
Thats novel.Ian Anderson wrote:Add an extra 3 litres of oil
paul c
Cheers Guys, I had been thinking of a priming tool as I have them for Ford v8s but I wasnt sure if that would be enough to get oil up to the pump, having heard what Rovers are like. I have done the overfill trick on other engines so had been considering that also. How does one check the relief spring, just in case, it has no cooler on this engine just an old basic 3.5. I had been thinking of swapping a 3.9 into it using this front cover but not sure I want to if the pump loses its prime.
The relief spring and its valve just sit behind a large bolt on the side of the oil pump, not much oil comes out when you take the bolt off. the spring should then come out followed be a 'slug of metal' which is the actual valve. This slug must be free to move up and down its bore.paul c wrote:Cheers Guys, I had been thinking of a priming tool as I have them for Ford v8s but I wasnt sure if that would be enough to get oil up to the pump, having heard what Rovers are like. I have done the overfill trick on other engines so had been considering that also. How does one check the relief spring, just in case, it has no cooler on this engine just an old basic 3.5. I had been thinking of swapping a 3.9 into it using this front cover but not sure I want to if the pump loses its prime.
If it was my lump I'd just have a go with the priming tool first. I would avoid at all costs cranking the engine until you get pressure using the priming tool.
plastic orange
Karel R.R. & Capri
Why would it damage the pump? You are just spinning it round the same way that the dizzy drive spins it round. Testing for oil pressure this way has the advantage that you are not turning the rest of the engine over which is the worst thing you can do if you have something dodgy going on.Karel R.R. & Capri wrote:![]()
priming a oil pump with a drill , cant it damage the pomp
I have never done this before
and a picture say's more than a thousants words
That's true, that's why a drill with a nice variable speed trigger is good along with engaging your brain whilst carrying out the task!davemgb wrote:Bigger danger of damaging yourself or the drill when the pump primes and the resistance increases !?!Karel R.R. & Capri wrote:![]()
