Master cylinder sizes ????
V8XR2
Post by V8XR2 »
Hi I need help if I buy a wilwood twin master cylinder pedal box what sizes of master cylinder do I need ?
Iv already fitted wilwood dinalite 4 pots on the front ( 34mm I think larger size ) m16 from mk2 escort
And already fitted rwd cossy calipers at the back don't know what size they are.
Thanks for your help
Steve.
http://www.youtube.com/watch?v=g3lxx0zW49c&feature=youtube_gdata_player
Hi it's a bit of an art to get the correct balance.
Example my GT40
Front runs Ap racing 4 pot calipers 268mm disc 225 tyre and is 40% total vehicle weight
Rear runs Saab 9000 turbo front calipers and a 265 tyre on 60% of vehicle weight - sorry cannot remember disc diameter
Using 0.625 masters on both I was locking the rears first - even with the balance bar cranked over
Now run 0.75 on rear and 0.625 on front - no boosters 6 to 1 AP pedal box and it is good once warm - until then I still seem to get more rear bias - probably need to adjust that out on the pad hardness.
Wilwood normally has a sizing sheet on their website that allows you to plug in all your dimensions and they will come up with a good "first fit" - it will work but need not be the best attainable
JSF55
Post by JSF55 »
You can have a read here, but your going to have too find out the rear brake size some how ?
http://www.hotrodheaven.com/tech/brakes/brakes3.htm
So thats where it went !
