Which direction on valve
danbm
Post by danbm »
Hi folks
I've just installed a 2nd hand lpg system and forgot how this valve/solenoid was connected.
Does it matter which side the tank is connected on or is that vital? It's a two tank system.
Dan
LR SIII 3.9 V8
demo2
Moderator Gold
Moderator Gold
Post by demo2 »
If u remove the bowl u will c that it has a filter inside, the liquid needs 2 come thru the centre of the filter and then fill the bowl and out the side :D
danbm
Post by danbm »
Thanks!
Seems like the screws has rusted, though...
Can i damage anything by having swapped the connections?
D
LR SIII 3.9 V8
Only by all the muck that's gathered on the filter being fired into the engine!
danbm
Post by danbm »
mmm... of course...
i'll try to clean it up with some brake cleaner or something...
Ta
LR SIII 3.9 V8
Return to “LPG Section”
