Dellorto Guru ?
Wotland
Dellorto Guru ?
Post by Wotland »
Any dellorto Guru here ?
I think to have seen somewhere 48's'carbs are 45's carbs bored.
Now about carbs set up, anyone has experience of this carbs ?
Thanks.
I am not a Guru, but to my knowladge the 48 dellorto has 45mm throttle plates the largest venturi they will take, like the 48 webber is a 44mm ( I think) but whatever it is the venturi sizes are the same as the 48 webber (which has 48mm throttle plates) so it was called a 48, and also because it takes bigger venturis than the 45 :? .
You are unlikley to find a webber or dellorto Guru these days, I would buy as many books on them as you can and become your own Guru.
Here's a tutorial on how to do Webers
http://www.gt40s.com/forum/gt40-tech-en ... utube.html
And more about Webers here
http://www.clubcobra.com/forums/weber-tuning/
IAn
gelmonkey
Sergeant Monkey Face
Post by gelmonkey »
What is it you want to know please?
I have some time spent on the 45's.
Paul
Wotland
Post by Wotland »
Thank all.
My quad 45's carbs are for 4.5 engine which can rev up 7500.
I opened my carbs and found :
Main Jet : 142
Emulsion tube : 7772.5
Air correction jet : 110
Idle air corrector jet : 7850.1
Long idle jet : 55
Cold start emulsion tube : 7482.1
Cold start jet : 70
Pump jet : 55
Needle valve : 1.75
Auxillary venturi : 8011.1
Choke : 38
So need of new set up for my engine but dellorto science is somewhat obscure to me :lol:
gelmonkey
Post by gelmonkey »
Are you running side draughts or down draughts please.
The info I have here is for side draught DCOE's.
P
Wotland
Post by Wotland »
gelmonkey wrote:Are you running side draughts or down draughts please.
P
Hi Paul,
carbs are DHLA side type.
gelmonkey
Post by gelmonkey »
Ok mate will pm you with the info that I have here over the weekend.
P
