LT77 oil seal collar
marcjagman
Does any one know how to remove the oil seal collar on an LT77? I know there is a special puller needed, which I don't have, can anyone sugest a way to remove it or how to make something to remove it or even have the right tool I can borrow/rent?
marcjagman
http://www.roversd1.nl/sd1web/index.html
does this help , i have stipped mine a few times and don't remember using a puller to do it ... are we talking about the output flange ? once you remove the centre nut that just comes off then remove the speedo drive and the 2 small plates on the top with the 10mm bolts holding them , once they are out you can then remove the rear case and the collar and speedo drive come off with it ... the collar on the shaft is not a press fit just drops on and is a spacer ...
marcjagman
NO, it's called an oil seal collar and it's a press fit. The gearbox was originally from a range rover so it's got a different output shaft for the transfer box to attach to. Here http://i422.photobucket.com/albums/pp30 ... 1265491217 and here http://i422.photobucket.com/albums/pp30 ... 1265491244 and here http://i422.photobucket.com/albums/pp30 ... 1265491283
ah , now if you had said its a rangey one ...sorry about that ..
they are completley differant inside from the 2wd ones ..even though they have the same name ...ooopppss
any good ... http://cgi.ebay.co.uk/large-GEAR-PULLER ... 5644393df1
marcjagman
