Wilwood confused
V8XR2
Wilwood confused
Post by V8XR2 »
Iv just got wilwood dynalite calipers
There are 4 bleed screws and nowhere
To connect the brake pipe do I use a
Bleed screw if so which one ???
Steve
gelmonkey
Sergeant Monkey Face
Post by gelmonkey »
I think you should find an input nipplle in the middle of the caliper between the pistons on the outside faces.
This is where you connect to.
Paul
V8XR2
Post by V8XR2 »
Iv got it thanks
