Axle ratio?
marcjagman
Axle ratio?
Post by marcjagman »
Quick one hopefully. Bought an axle that was supposed to a Cortina atlas, and it looks like it too. No ID tags on it. Been told by a so called expert that it's actually a klone? axle. To find out what the ratio is do I secure one end and turn the input until the other wheel end turns once? Currently turning approx 1.5 turns to wheel studs 1 full turn. Sounds a bit wrong to me.
r2d2hp
Post by r2d2hp »
Think you then multiply that by 2. 3 as a ratio however would be a little low for a cortina axle
To do it precisely, yes, fix one wheel, then turn the pinion. However for best accuracy, you need to find the minimum number of WHOLE turns of the pinion to give a WHOLE number of turns of the free wheel. You might find it's a pretty high number!, e.g. 50ish. Both numbers will probably be odd numbers, possibly even prime numbers!
Then divide the number of turns of the free wheel by two, and use that with the pinion turns to give you your ratio.
marcjagman
Oh crap, working out at about 4.2:1, not good. Is there a way I can be sure? There is a chap on ebay sell different CWP's at a resonable price and if it is an atlas then I can fit those and get 3.09:1 which is much better.
Darkspeed
Post by Darkspeed »
If its the Cortina axle - has the lugs on the top of the Diff housing There are two types of Axle - One has a flange where the diff cover fits' and the other does not. They are both Salibury (Atlas) Diffs
The non flange is the 1600 axle the flanged being the 2000 - Typically the 2.0L axle is 3.75 ratio and the 1600 3.89 and 4.11
Better to find a 2.0L MK2/3 Capri axle - Typically 3.44 and one of the cheaper live axles around with a suitable ratio.
To tell for certain its very easy - you remove the diff cover and its usually stamped on the pinion. - Gaskets are very cheap.
Andy
4.5L V8 Ginetta G27
marcjagman
Sounds like it's from a 1600 then, definately a koln axle as cover nuts are over to right slightly, according to the Ford forum. 54 inch long which kind of enforces a koln axle. Anyone got a capri atlas axle going cheap?
r2d2hp
Post by r2d2hp »
FYI - You can also get a 54" Atlas
marcjagman
r2d2hp wrote:FYI - You can also get a 54" Atlas
Found that out on the Ford forum but I definately have a koln axle as the top and bottom cover bolts are ofset to the right
