How to start a 3.5 rover v8 Simply????
roverv8tom
Post by roverv8tom »
Hi guys i just bought a rover v8 its on the floor all there ready for its test start but i dont no alot about wiring, well i dont no nothing, so can you tell me the most basic way of wiring and what i need to do just to turn it on and get it going so, where do i connect the coil and the starter motor etc etc, thanks for your help its an old v8 so uses points on the dizzy and stuff
why do v8 engiines send chills up your spine
If it's points, then it's pretty easy.
Bat +ve to starter big terminal on the back. Bat -ve to the engine block.
Bat +ve to coil +ve
Coil -ve to points
Then connect the small spade terminal on the starter to bat +ve and it'll spin over and you'll be away.
Remove bat +ve from coil +ve to switch off.
The starter might have two spades, not sure which one you need.
I think that's all you'll need.
roverv8tom
sorry call me stupid but what does ve mean
+ve = posotive = red terminal on battery, -ve = negative = black terminal on battery
roverv8tom
ok thanks guys i will tell you how it go's, i have a big fat wire in a black sheath that is bolted to the back of the sarter where it screws to the block whats this? cheers
marcjagman
Post by marcjagman »
ChrisJC wrote:If it's points, then it's pretty easy.
Bat +ve to coil +ve
Coil -ve to points
What if it's electronic ignition? DLM8 for example. Only asking as I'm in the same situation, very soon.
Post by CastleMGBV8 »
You are bolting the engine to something solid I hope?
Bat +ve to coil +ve
Coil -ve to points
Almost the same. The difference is that there are two wires between the distributor & coil, one for coil -ve (white & black), and one for coil +ve (white only).
Bryan
Post by Bryan »
This all assumes that you are on carbs. If you are on an efi system, more wiring is involved (though not really more difficult)
All the required info is included in previous posts - a search should provide everything you need
marcjagman
Thanks, car electrics are black magic to me, that's why I use carbs. Where do the wires from the coil go to? I presume +ve goes to live feed via ignition does the -ve go to earth or battery and does it make a difference or does the coil only have a live feed?
marcjagman wrote:Thanks, car electrics are black magic to me, that's why I use carbs. Where do the wires from the coil go to? I presume +ve goes to live feed via ignition does the -ve go to earth or battery and does it make a difference or does the coil only have a live feed?
Haynes do a very good book on car electrics which covers all the basics - as well as more advanced stuff. Unlike most Haynes manuals, it's well worth buying.
If such things really are a black art to you, it's best to either learn about them or leave to someone who does understand them. As bodging invariably ends in tears.
marcjagman
Will try and find that book. I have fitted full looms before but they usually come with a wall chart, labels etc as I've built loads of 7's in the past. So, what wires do I need for the coil? +ve to ignition, does the -ve need wiring or is that just for the rev counter?
Have a look at '3.9 EFI - no spark from coil' thread in this section. You'll find a wiring diagram for the DLM dizzy and coil etc courtesy of Ramon Alban.
marcjagman
Fantastic, now totally deaf as it fired once carbs filled up. Cough and spluttered for a bit to blow cobwebs out then settled down. Now to strip down and rebuild. Been collecting bits for years, now it's time to fit them.
:racing
