BMW M60 e34 v8 into an e36 m42 wiring help PLEASE :( :(
beelzebubs
Post by beelzebubs »
I need help, I really do.
I found a web page for the e34 loom into an e30, and was hoping this would help, but niet.
the diagram I have, says which pin to which pin, and the colours of said wires from each pin.
but my e34 loom, even though it says this is the loom to use, has different pins, and different coloured wires.
this is the diagram I have
and below is the actual pin numbers and colours, from both the e34 v8 loom and the e36 4 pot...
can anyone help me out here. free tattoo to anyone who wants it and can get me sorted :)
e34
01 blu/wht
02 blu/wht possibly pale yellow
03 thick red/wht
04 blk/blu
05 blk/grey
06 magenta/grey
07 thick green
08
09
10 brn/blk
11 brn/yel
12 brn
13 thick green/pur
14 blk/wht
15 blk/grn
16 wht/yel
17 why/magenta
18 blk/yel starter
19 wht/grn
20 blk
21 thick green
22 thick grn/wht
23 brn/grn
24 wht/blk
25 blu
e36
01
02
03
04 blk/blu
05 blk/gry
06 magenta/gry
07 grn
08
09
10
11 brn/yel
12 brn/magenta
13 thick grn/magenta
14 blk/wht
15 blk/grn
16 wht/yel
17 wht/mag
18 blk/yel starter
19 wht/grn
20 blk
21 thick green
22 thick grn/wht
23 brn/gry
24 wht/blk
25 blu
beelzebubs
all the pins that match are pin for pin colour for colour, leaving 4 wires on the v8 loom not in use, pins 1,2,3 and 10
could it really be that simple to just match pin for pin colour for colour?
also pin 7 on 1 is like 2.5mm thick green and on the other its a thin 1mm green?
beelzebubs
so if its pin for pin, what do the highlighted wires do? any ideas?
beelzebubs
okily dokily, I joined like for like, as best that it would
on the e34 end I have 5 wires that dont line up either to colour or pin
pins
01 blu/wht
03 thick red/wht
do not line up to the e36 plug, the e36 plug has no wiers in pins 1,2,3
pin 23 on the e34 end is brown with green trace, where pin 23 on the e36 end is brown with a grey trace.
and pin 7 on the e34 end is thick green, and pin 7 on e36 end is a thin green.
now on the e36 end, i have a fuel pump wire pin 13 that goes to a relay Siemens V23134-K59-X170 with 12.62-1735424 on it, on this realy i have 3 unconnected wires, a thick red, a thin red/white and a thin brown/green. where the fuel relay wire (pin13) goes into this realy, a thin green magenta comes out and goes to another relay Siemens V23134-K59-X222 with 61.36-8366600 on it, of this relay i have another 3 unconnected wires , a thin brown/green, a thin green and a thin red/white....
any help greatly appreciated
e34 end
e36 end
