Turbo & Blow Through Carb resources
IainB
Post by IainB »
Quick question to those who like to be blown :oops: :twisted:
Can anyone recommend any books and/or resources that would give info on a blow through carb setup?
Im having stupid (and silly!) thoughts about sticking a couple of turbos on the 502 8) and blowing through a modified Holley - but its in need of research at the minute - nothing silly, a 200 / 250 increase would be nice
Had been thinking of a progressive Nitrous system, but am now swaying more to a bit of FI action
Iain
Iain,
you thought about contacting Jay? (blown yellow porka)
IainB
Post by IainB »
thev8kid wrote:Iain,
Hes running a ProCharger (same principle though!) could well be worth a shot
Im looking at more of a DIY setup for this, wont be pretty, but hoping it will do the job, all a bit of a steep learning curve
Post by ian.stewart »
you can of course run the carb in a closed plenum, so pressure is equalised and you dont need a special carb, but you do need rising rate fuel pressure so you dont push the fuel back along the fuel line,
chodjinn
Post by chodjinn »
I'm sure boostedLS1 or stevieturbo will chime in soon I think they've both had a fair bit of experience with blown carbs. I know Demon Carbs over the pond can tailor carbs to your engines.
Iain, I have just remembered my mate has a FULL Gale Banks set up for a SBC, Porsche Racecar Turbos and wastegates,and the BIGGEST air to air intercooler you have EVER seen, it would be hard to lose on an Iveco let alone a Chrysler
Ian :D ,
chodjinn
Post by chodjinn »
Ian, doea your amte have any pics of the Gale banks set up? I would be quite interested in seeing it. Is it installed on anything at the moment, or is he selling it etc?
Its up for sale, knowing him it wont be cheap.
IainB
Post by IainB »
I may be gone a while :nw http://www.turbomustangs.com/smf/ :nw
Hours and Hours of reading....woot!!
You know, im really considering doing this now :nutz :nutz and by the time its finished this sort of car wont be allowed on the road probably!!
I used to blow through a Holley 600DP. Then modified it to a 465 SP as the 600 was too big for the Rover engine I was using.
These things can be tricky to set up to work nicely. I would contact Jay, and find out who he got his carb off. In the long run, it will be easier to buy one from a specialist, who has an idea of how to set them up properly for boost, right from the word go.
As doing it yourself, will be a slow and tedious process.
I dont think I'd go for a yellow carb like Jay did though lol.
IainB
Post by IainB »
stevieturbo wrote:As doing it yourself, will be a slow and tedious process.
Thanks for the info
Im no longer in a rush to get the car finished, lifes to short to get stressed over a car build....as for yellow...mmm :D mine (if I do go this route) will be 100% barn find / DIY so im probably looking at a nice rust / corroded alloy look :P
Thanks for the info
I understand where you are coming from......but between petrol costs etc for testing....
It will likely work out cheaper in the long run to buy a carb that is already almost setup for your application.
Often, trying to save money, can cost you in the long run. Believe me, Ive thew away thousands over the years.
That said, if you want a 465SP that I was using, its still here lol. It has a plenum already made for it. Maybe not the neatest in the world, but it works fine.
Car would obviously require re-jetting etc to suit.
it was a 465 vac carb, that I fitted the 600DP fuel bowls to. It ended up as a 465 SP, with a larger 50cc pump jet.
mrmad
Post by mrmad »
hi iain
i got my carb custom built to my engine by these guys http://www.csucarbs.com/ the guys name is kevin and all i can say is that he knows his stuff when i was on the dyno he was on hand for advice
not had any problems with his carb at all
here allso is a link to doin a carb your self very use full http://www.hangar18fabrication.com/blowthru.html
hope this helps
beware boost makes power and power breaks things alot im really finding this out :(
hey stevie whats wrong with the yellow :lol:
jay
LETS RACE
Hi Jay,
glad to see you have rejoined us mate 8)
mrmad wrote:hi iain
hope this helps
jay
What have you broken now Jay, was allright when we were up the Pod
Return to “Forced Induction”
