Judder on LPG
Judder on LPG
OK, my P38 is exhibiting the most peculiar anomaly:
It's a 4.6 with OMVL Dream 21 LPG.
Runs perfectly on petrol. Runs perfectly on LPG at light to moderate loads. But:
When under heavy load between 3500rpm and 5000rpm, it judders pretty badly. Perhaps not as regular and harsh as a total misfire, but very very jerky nonetheless.
I've done some diagnostics with the LPG software and an OBD-II reader, and the following are true:
1. The Injector times go wild when it judders
2. The MAF reading goes wild (is 80-90 when on petrol, jumps up to 270 when on LPG!)
3. TPS is steady
I can't understand why it should be perfect on petrol, yet not OK on LPG.
Any ideas?
Thanks,
bodger
Post by bodger »
Hi Chris :)
have you looked at the HT leads for tracking , mine old one used to do that on LPG but not on petrol ..it was tyhe HT leads breaking down as they coped with petrol but not Gas ...
Re: Judder on LPG
ChrisJC wrote:OK, my P38 is exhibiting the most peculiar anomaly:
3. TPS is steady
Any ideas?
Thanks,
Any EFI system depends on a reliable tach signal from the ignition. And a good clean supply of battery volts, including the ground. Corruption of either could cause your problems
My guess is the tach signal. Have you a method of logging it?
Thanks chaps.
The 'tach' signal is OK. I know this because the rev counter is stable on the gas diagnostic software.
I wondered about the leads. I'm reluctant to fork out for a new set without proof, as they're dear for a Thor engine, and they are less than a year old. Mind you, they were 'pattern' leads rather than super-duper expensive ones. Rimmers want £101.22 for a genuine set!!
I think I'll strap a video camera under the bonnet and go for a drive. See if there's any evidence of tracking.
bodger
Post by bodger »
buy some copper core cable Chris and pull end off an old set of leads you can then solder them back on the new wire ( don't forget to put the caps on first though ...i forget :) )
I have ordered a set of super-duper (not Magnecore!) leads from eBay...... Shall see if that makes a difference.
bodger
Post by bodger »
fingers crossed Chris , when i went to TINLEY TECH a while back he said that even the OE leads only last 6/12 months tops on Range Rover with LPG ... they just eat them appaently
FIXED!
Turned out to be the MAF.
I'd fitted a £40 eBay pattern MAF. In desparation I bought a genuine part from Rimmers (£140), and it's perfect!
I had tried 3 sets of leads, to no avail in the meantime.
bodger
Post by bodger »
Glad to hear its sorted , things like thsi can be a right pain to find ....
Return to “LPG Section”
