Thread sizes
Blackflag533
Thread sizes
Post by Blackflag533 »
Evening all,
Whats the thread size in the cylinder head for the inlet & exhaust manifolds on a 3.9 Rover V8...?
I'm in need of a helicoil or 5...!
Thanks in advance.
DEVONMAN
Re: Thread sizes
Post by DEVONMAN »
Blackflag533 wrote:Evening all,
Thanks in advance.
3/8 unc for the exhaust and I think the inlet is the same
Regards Denis
Blackflag533
Re: Thread sizes
Thanks in advance.
Regards Denis
Hello Denis,
That was quick!!
Thanks very much. :)
spend
Post by spend »
They are both 3/8 UNC.
Typically there is enough depth of thread in the heads to use longer studs / bolts on the exhaust if you clean/tap them out. The inlet is of course at an obtuse angle so you have to be really careful running a tap down them but I'm pretty sure there is quite a bit of room in them to use 1/4" longer bolts as well.
