Heater tube removal and replace.
bevel drive
Post by bevel drive »
Hi, Does anybody know how to remove the heater tube from the SU inlet manifold it's the front one. I have removed the core plug and the tube is very rusty and has holes in it. I have another manifold and it's just as bad
Regards Ray.
I would drill it out, I suspect you may have to make good the area around the pipe by dilling out oversize and making up a bush to get you back to the original sized pipe.
best regards
bevel drive
Hi Mike, Thanks for the info, I will drill the tube out and replace it.
Regards Ray.
Return to “Cooling Area”
