do all engines use the same rear oil seal
or do the 3.9 and 4.6 use the same
i got to take engine out to replace mine .can i replace with out removing the bearing cap.
regards pete
rear oil seal
- russell_ram
You can definitely change it without removing the crankshaft.
I don't see why you can't remove it and keep the rear bearing cap in situ.
Be aware that there are cruciform seals in the rear bearing cap which must seal properly, and further, I have had oil leaking down the threads of the two long bolts holding the sump on under that part of the engine!
Remember it's a Rover
They are either incontinent or trying to mark their territory - I can't figure which
Regards
Regards
