Can someone explain why this would happen?
Engine is RV8 springs are real steel DW060 one coil less than OE.
Valve lift 12,7mm, spring dosen´t go on tube.
Shimmed to 40,4mm realsteel recon 39,3mm? So i think its not a proplem?
Drived about 2600km and revs are max 6000rpm..
Is it faulty when it leaves on factory?
I but new spring in to the head, and now she is running again..
Uploaded with ImageShack.us
