oil pump
littlewarby
oil pump
Post by littlewarby »
hello hello hello
any one know about rover v8 1987 carb 3.5 in a a landrover, oil pump/gears
as just replaced pump cover with moded 1 & a geared wheel feel out as i took off old cover.
Fitted said wheel with new pump cover & now no oil is being pumped
around engine
do's it need priming?? if so how
thank you thank you
Pocket rocket
Post by Pocket rocket »
You could take it apart and pack the oil pump gears with vaseline.
Or you can take out the distributor, get a tool with the correct end (for the oil pump drive) and put it in a battery drill - keep whirring until you feel the pressure
Yes, it needs priming.
Pack the pump with vaseline
V8Smudge
Post by V8Smudge »
I just used a long M10 threaded bolt, cut the head off, and ground a groove into it to mate with the oil pump drive, most drills will take the 10mm diameter in their chucks easily.
Land Rover SIIA 88" fitted with a 180BHP V8
Some is good, more is better, and too much is just enough!!
littlewarby
quick
thanks lad's
that was a fast reply
will do as soon as
