Inlet air sensor position
I've converted my flapper EFI RV8 to MegaSquirt.
The original air temperature sensor is in the flapper AFM. I've replaced that with a bit of ally tube and fitted the air temp sensor to that. Is this the ideal position?
polredt5
Post by polredt5 »
As close to the throttle body as you can, :D
It will be fine.
Isnt overly important where it goes, as often OEM sensors are anywhere near the engine anyway.
