ROVER V8 FLYWHEELS
j.johnson23
- Helpful or Confused
ROVER V8 FLYWHEELS
Hi all.I`m new to this site and would like to know what the difference is between an sd1 flywheeel and a range rover flywheel.Thanks in advance.
- topcatcustom
- topcatcustom
- topcatcustom
Hi Guys
Dimensions for RR flywheel from back of ring gear to clutch face.
Range Rover 11.70mm.
SD1 7mm. Not the 10mm I thought it was
Think I have a clutch in bits for next project here so if I get time tonight I will measure up and post details.
Regarding your prop Tom, have you tried Reco prop for a quote?
Paul
Paul
