"Try to get it to go along in 3rd at 30mph 1700 rpm and it will not cruise in a line of traffic and bucks like a bronco on kangaroo petrol."
this is what happens to me, but the difference is that my engine is supposed to have a JE101 cam and from what I've read, the JE101 is a mild fast road cam.
Here's the spec (what previous owner remembers) :-
engine acid dipped and totally rebuilt by JE Engineering
heads fully balanced & ported
double-valve springs
triple-valve seats
JE101 cam
adjustable Vernier timing chain set
centre pull plenum butterflies
adjustable fuel pressure
high pressure oil pump with sperm-type relief valve
JE Engineering stainless steel exhaust system, incl tubular manifolds.
KONI adjustable shocks
JE uprated lowered springs
Mark Adams E-Drive ECU for FLAPPER-type EFi
When I'm out in it around town or residential areas (30 limit), very rarely do I get into 3rd and be able to stay in 3rd at 30mph (car starts to buck) and so I drop it to 2nd until I leave the 30 area and then perhaps get it into 3rd doing 40mph or more. The car just wants to go fast and I always seem to find myself stuck behind slower traffic always holding the car back.
The Mark Adams E-drive ECU is something I added as the ECU needed remanufacturing as it had a bad intermittant fuelling fault.
Are these the driving characteristics you would expect from an engine with the above spec?
Is the above spec what someone would have done if they had a heavy right foot?
Sorry to go on
