The method specified on the RPI web site for setting cam follower pre load looks a little hit and miss and can't be done on a built up engine, my proposal is therefore following am I missing something?
1. Put spacers between the rocker posts and followers until there is clearance on all valves (when valves closed), in my case this was 2mm.
2. measure the valve clarance turning the engine as you would to set the clearances with solid lifters.
3. calculate the pre load using a rocker ratio of 1.6,
preload = (Gap/1.6) - (shim thickness*1.6)
Do this for all 8 per side, in my case preloads were :(in mm)
-3.20,-2.45,-3.11,-2.70,-3.11,-2.67,-2.61,-2.51
Aiming for a target of between .5 and 1.3 mm gives a shim of around 1.2 mm (1.6 x the shim = prelead change) just about brings them all in range.
Any thoughts?
Kevin
Setting pre load
Setting pre load
Kevin S
Heres a good guide
http://www.morgandoc.com/How_do_I_set_t ... -load.html
Also don't forget yiou can swop pushrods around to try and get the loads spot on
