return pipe
return pipe
stagman
When a fuel return pipe is run (mainly injection) the return should be the same size as the flow pipe (It has to return the full pump flow when the engine is at idle)
Presumably you are running an interruptor (Facit red top / SU or similar) pump.
If so where is your pump mounted?
If in the engine bay the under bonnet temp could cause the low pressure liquid fuel (before pump) to go to gas state and an interruptor pump cannot pump gas (normally mentioned in gumph that they are not self priming)
If this is the case try mounting your pump near the tank (and low level) instead so it Pumps instead of sucking along the long length of pipe (After all they are called pumps and not suckers)
This may mean you do not have to run extra pipes which may not in the end solve your problem
