Buying a T reg Disco with LPG
star100
Post by star100 »
I've seen a T reg Disco and it has LPG fitted. Its Done 85,000 miles, and i wondered if the mileage would be a problem on it? It has got full land rover service history..... Or would i be better off getting one with lower mileage?
I did have an N reg Disco on LPG but it gave me nothing but problems. It had the same sort of mileage on it.
If you could give me your thoughts and advice that would be great.
Thanks sarah
It should be fine provided it's a good quality LPG conversion (i.e. not a lashup done in somebodies shed!).
Under those circumstances it will be no better / worse than a standard LPG Disco.
I've put 50K on a V8 solely on LPG, and it's not suffered any more than a petrol one would have done.
bobtail84
Post by bobtail84 »
My RV8 has over 120000 on it and I run LPG almost all the time without any probs.
jeff
Range Rover 3.9 with MegaSquirt and EDIS
www.essex-ms.co.uk
slice
Post by slice »
My 1998 disco I 3.9 V8 has an old single point lpg system fitted ( so i guess it was fitted quite some time ago). i bought it 10 months ago with 102k on the clock. I've done 21k in it since then and it hasnt missed a beat
SLICE
Return to “LPG Section”
