ROVER V8 LT77 GEARBOX CLUTCH SLAVE
scimitar0
Post by scimitar0 »
I am currently fitting a rover V8 to my scimitar SE5A, I have misplaced the bolts for the clutch slave cylinder for the LT77 gearbox, doh ! can anyone tell me what size and thread they are please ? :oops:
Phil
Phil
Andy515666
Post by Andy515666 »
Hi Phil
I had the same problem and when I used what I thought were the right bolts i ended up threading one of the holes.
After much loud vocal abuse at myself I ended up getting a tap set and re threading both holes to fit different bolts. I wlil have a look tonight and see what the side of the bolts are.
Andrew
Chur Bro
jrv8
Post by jrv8 »
Hi ,
Thread size is M8
an M8 x 35 bolt should be ok for length.
Regards
Jim
scoobyv8
Post by scoobyv8 »
jrv8 wrote:Hi ,
Thread size is M8
Regards
Jim
i'm guessing you mean M8 by 1.25 pitch, by 35 mm long
just thought i'd clarify that, to keep the chap right
George
The refinement of modern day comfort, and the prestige of a rover V8! In the making.
