Hello,
Someone know if standard lifters accept adjustable pushrods with 3/16" end or ends need to changed for 5/32" size ?
Wrong ends can explain noisy lifters and may be problem to keep correct preload if the end of pushrods doesn't seat correctly in lifter ?
For me standard lifters need 5/32" ends but need confirmation.
Thank.
Adjustable pushrods and standard Lifter
Dimitri,
For simplicity the standard lifters should require the same size ball end as the rockers.
I found that some aftermarket lifters, Crane hi rev and some Rhoads lifters and possibly others require the chevy size ball.
Just try the pushrod in the cup and see it it seats properly, put a bit of engineering blue on the ball if you want to make sure.
