Hello to all.
I have been looking at all of the comments regarding the spider plates and Perrys use of stock internals in his 4.6.My question is this, I have a 4.3 Rover which has been lightened, balanced,and blueprinted and an aluminium flywheel with twin plate clutch forged rods but only Hyperutectic pistons.
A Super powershot NOS plate system has been fitted but not yet used and I now have concerns that this may not give me what I am looking for.
How much better is the spider plate and will the pistons handle a full shot of gas?
Am looking to run about 100bhp extra with the gas.
My goal is to run 12s without gas and 11s with.
The motor is fitted to an old Cavalier coupe by the way.
Thanks in advance to replies
Question Re Stock bottom and spider plates
As Rich say's. Stock pistons will take a 100 shot all day long. As long as the timing is tweaked a bit.
If you dont have the right inlet manifold to accept a spider plate. Then get WON to make up one of their quad crossfire plates. Much better than a nos plate any day. Much better and even distribution and atomisation.
If your motor is making the right numbers off gas, and you have enough gears (which I dont) then you should break a 12 without too much hassle.
Hi Guys
Thanks for coming back to me so quickly.
I am running the Edlebrock performer manifold with the Webber 500 so this should be okay then methinks.
I have a Vitesse Thunder Saloon 5spd box nailed to the back of the motor and a 3.67 lsd so with luck the twelves are a good possibility.
Will have to get the car set up properly once she,s on the road.
Its taken me twelve long years to get to this stage and I can hardly wait to get back out raod wise and trackwise.
Paul
Paul
