Range Rover in-tank pump dimensions
kev_the_mole
Post by kev_the_mole »
Anybody know the depth from flange to pump base of this RR P38 4.0/4.6 94-98 injection pump?
want to fit it in here to eliminate the need for a swirl and external pump
JSF55
Post by JSF55 »
I think i used this one on my efi conversion
http://cgi.ebay.co.uk/RANGE-ROVER-CLASS ... 7C294%3A50
Managed to trim it down to about 7" tall to fit in my tank, worked a treat :D
So thats where it went !
kev_the_mole
Do you know how deep it was before you modified?
JSF55
Post by JSF55 »
I don't think i shortened by more than about 2 inches, 2 1/2 inches tops, i have a better photo of that pump here, next to a pen to reference the size, pm me if you want a copy of it sent, john
kev_the_mole
John,
PM sent.
mjheathcote
Re: Range Rover in-tank pump dimensions
Post by mjheathcote »
I like the look of this for my Stag EFI project, but how do you mount it to the top of the tank?
The earlier RR one is easier to mount, but does not have an inbuilt swirl pot arrangement.
Mike.
kev_the_mole wrote:Anybody know the depth from flange to pump base of this RR P38 4.0/4.6 94-98 injection pump?
kev_the_mole
Mike,
from what I've seen you cut the hole in the tank to fit the sender and the gaskets and then fabricate some sort of circular or hold down clamps.
Ive got a sump in my tank so I'll place the pump in that and just modify the length. That should get rid of the need for a swirl pot.
