I have a Rover 4.6 block from 1997 that I have been planning to use for an MG V8 conversion. I have removed the valley gasket and there is no sign of any wall thickness numbers or paint dabs anywhere on the valley wall. In "How to Power Tune Rover V8 Engines" it says that before the factory went to the paint dab method of grading they "started ultrasonic testing -by hand- of wall thicknesses of all engine blocks and recording what each blocks wall thickness was".
Does anyone know if this information was recorded on paper or just recorded on the block? If it was written down can Rover (maybe the traceability department) look up this information by the engine number?
"Recorded" Wall Thickness
4.6 MGBegun
im afraid i cant shed any light on it but info recorded in those books isnt always entirely correct
i have it and its a good book, but unfortunately like most books of that type its a bit 'armchair mechanics'.
also it might have had hte paint dab and a previous owner might have removed it thinking it was a blemish or such like
however im sure one of the exerienced members of the forum will shed some light on it
Zander
I think it is most unlikely that you will find any information as to the grade of the block.
If you are looking for confirmation that the block is sound then I can only suggest that you have it pressure tested.
A visual inspection with the heads off will show if there are any liners that have slipped lower in the bores, as will and signs of any of the cylinders looking as if they have been steam cleaned.
4.6 MGBegun
60K + clean doesn't mean that it's OK. Those blocks are notorious for failing. I would definitely take the opportunity to get it pressure tested whilst it's convenient rather than build it up only to find it leaks water internally somewhere!!
